forgotten my pin code
SOLVED
aniketushetty
Visitor
i seem to have forgotten my pin code...
so i called my mobile opperator for the puk code..
but even after entering my pin code wrong for atleast 110 times..as opposed to 3 times
its still asking me to enter pin code after 30 sec..
pls help...
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
use SUS to delete everything on your phone
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
for future reference
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget to mark the Correct Answers & Helpful Answers
7 REPLIES 7
Uliwooly
I don't think that's the PUK code but the pin lock code, try to remember which pin lock code you set to lock the screen
Uliwooly
aniketushetty
Visitor
thanks a lot uliwooly...!!!
Uliwooly
anytime
jrxau
Visitor
If you haven't changed your pin by default it should be the last 4 digits of the PUK.
Anastasia13
Visitor
Hi, my Sony Xperia Z1 has the same problem, it is asking for some PIN, which I don´t know and after every 5th wrong PIN I should wait for 30 sec.
And I was trying to installthis hardware, but it is not up-to-date or stopped working...
dw13
Visitor
Hi I have forgotten my pin password to get on. everytime I get it wrong it says wait 30 seconds.  And its getting really anoying the type of phone I have is Sony Xperia z5.  What should I do
