Camera z2
SOLVED
Gra
Visitor
Camera z2
I don´t like that the cammera takes the pictures in 8 megpixeles, so I put the manual mode, but then I can´t use the scene mode nor the Hdr mode. They don´t work.
I´ve tried to reinstall the software but It also says that I can´t make a copy. So I´ve bought the movil because of the cammera and I have a normal one.
Sorry for my english.
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.RO.title
_alexdon_
You need to put it on 8MPx on manual mode to be able to use HDR.
alexdon
3 REPLIES 3
_alexdon_
alexdon
Gra
Visitor
Thank you very much. So finally I have a 8 megapixeles camera. Slightly_frowning_Face
_alexdon_
you have a more powerful one,do not worry.
alexdon
