Hi. I just upgraded to 5.1.1
But applock and smart app lock does not work anymore.that's very important to me.
Who else has experienced the same problem? If u know any solution, let me know pleasr. Thanks
Solved! Go to Solution.
It's a new update, app developers have to check and fix this compatibility issues, not Sony. If the app was developed by Sony, then Sony will have to address the issue.
i have same issue please help..!!
You have to contact the app developers, its up to them to address this issue.
I tired more apps but none of them work !!!
Maybe the problem is related to the new ROM - not the apps
yeah exactly.... i tried lots of other apps thay are not working too... this problem comes after new update to lollipop !!
Go To Phone Settings --> Security --> Apps With Usage Access --> Enable AppLock
After updating App LOCKS not working
I Have SMART APP installed on my cell phone, but not showing on the security->Apps with usage access
is the app itself that has to request permission to be included in " Apps With Usage Access". Clean Master applock already does.
I contacted "Smart Applock" support and they said they would solve as soon as possible
