applock and smart app lock does not work on 5.1.1
SOLVED
avacs
Visitor
Hi. I just upgraded to 5.1.1
But applock and smart app lock does not work anymore.that's very important to me.
Who else has experienced the same problem? If u know any solution, let me know pleasr. Thanks
26 REPLIES 26
priyansh
Visitor
Or u can try going to settings(system) -> accessibility -> turn on app lock services
Hope it works
Kim79
Visitor
Need to remove pattern lock don't know how it was put on my phone
GKS_GGN
Visitor
Thanks for following solution, its working :
Go To Phone Settings --> Security --> Apps With Usage Access --> Enable AppLock
PM-007
Visitor
Tried it, not working
Yogendra_Kher
Visitor
I tried it but app lock apk is not showing in the list.
What to do?
Don008
Visitor
There is no Apps With Usage Access, What to do then?
I have huawie y6 pro and Android 5.1.1.
Sipun
Visitor
Why MyAppLock is not Locked On The Marsmallow
