Z5 tethering error
Janperez
Visitor
Z5 tethering error
Hi, i had a brand new experia z5 from valencia spain.
But my mobile data tethering feature is not working. It says tethering error. Can anyone please help.me with this?
8 REPLIES 8
Uliwooly
@Janperez
Does your network allow you to tether your data?
Janperez
Visitor
Yes.. I tried my simcards on different phones.. I works on tethering. But not on my z5
Uliwooly
@Janperez
Does it work while on >>> safe mode
Janperez
Visitor
Ill try.. But i gues it should be properly working on safemode.
My.phone displays an orange network. Icon upon starting .i believe this was not openline .. The retailer just had it unlocked when i purchased
Janperez
Visitor
I mean i should be properly working even not on safemode
Uliwooly
@Janperez
Have you tested on safe mode ?
Christofer
Champion
Hi @Janperez,
This could be caused by incorrect APN settings.
Try clearing your current APN settings,
Settings > More > Mobile networks > Access Point Names > [menu] (the three dots) > Reset to default.
Download your current network providers APN settings again after doing this,
Settings > More > Internet settings,
then restart your phone and try using tethering again.
Sam343
Visitor
I have the same Problem with my Z5 E6653  !!! i did framat the phon and i did check the APN setting , but thing works untill now ?!!! O.o any Idea ...
