So, I had a lot of problems with battery drops, today I fixed it by using the Xperia companion and doing the software repair. After charging it fully and doing some stuff on it I knew it was fixed (for now lol). I made a backup before the repair and now I want to restore that, however, when restoring the backup it proceeds as usual until a certain point, which is:
The following content can not be restored:
com.a0soft.gphone.app2sd
Which has something to do with the app app2sd I had installed, I can't seem to get past this. It just says it can't complete the backup.
I've tried restarting both xperia companion and the phone.
did you try other backups? try to restore from google
settings>backup&reset
did any of the options had synced your data>
