Headphone jack (?) problem
velu
Visitor
Head set jack not deducting on my phone i am using xperia ultra t2.. can any one sugesst wat i can do on this???????
6 REPLIES 6
profile.country.RO.title
_alexdon_
Are you using Sony headset? Try to clear data for smart connect app.
alexdon
velu
Visitor
yeah i am using sony head set... i clear smart connect cache and clear data same problem its occurs.
_alexdon_
Grab a pair of tweezers and clean the 3.5mm input.
alexdon
Kish0
Visitor
Was water spilt over it ? If yes just clean the whole phone using a micro fiber cloth and blow some air into the audio jack hole. And give some decent amount of time for phone to dry.
Garv
Visitor
Dear Sir,
I have a problem in my sony t2 ultra dual, in which when i remove my headphone a notification occurs - connected headset
and also i am not able to listen songs because speaker are not working because of the headset connected notification
Raj_Rajput
Visitor
and also i am not able to listen songs because speaker are not working because of the headset connected notification. Even i am unable to speak on call with mobile speaker, compulosrily need to connect headphone to speak.
plz help.....
