hello,
My question pertains to the Sony configuration extension version 1.0.0.A.0.4 which appears on the Google Play store.
Is this to be installed? I ask as on numerous reviews it says that it isn't supported any longer.
If this is the case why can't it be uninstalled?
The only option is to force stop it in settings, but I'm unsure if it is alright to do this?
My version currently is 1.0.0.A.0.0
So should I be installing the version currently on the Google playstore which is 1.0.0.A.0.4? Or not?
Thanks.
For some reason after I posted this the later version doesn't appear on Google playstore any more but has installed on my phone without me knowing.
At least it doesn't show to be updated now.
Test
