No EDIT /share/delete option when capturing screenshots
SOUNI1
where are edit/share/delete option??
profile.country.PH.title
MarlonUk1
i just replicated it with my XZ, it wont show when you have priority notification, can you try to clear the notifications and take a screenshot again
5 RISPOSTE 5
MarlonUk1
i can't see the image until approved by a moderator. can you try to upload it with link?
right after you take a screenshot, if you pull the notifications bar you will have share and delete options.
as for edit you need to view the image on the album app and select edit
SOUNI1
MarlonUk1
I think it is because you are viewing the my xperia notification, can you try to slide it up a bit?
MarlonUk1
SOUNI1
Here you go...
https://drive.google.com/file/d/0Byy3PUewHDFCekdMYl81MUVYdEk/view?usp=drivesdk
Now i see delete/share option... Thanks
