The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
I'd like to say thanks to everyone who send us logs of this and again apologize for any inconvenience this is causing.
I've just received information that a new software update will be available shortly with a solution for this.
Until the new software update is available, if the accelerometer, gyroscope, magnetometer, ambient light, proximity sensor, barometer or screen rotation stops responding, please try to restart the phone as a workaround.
If it only happen every now and then it'll be really hard to figure out which app it's causing this
It's NOT a single case so it probably not a S/W issue but a H/W one caused by overheat.
I quote http://forum.xda-developers.com/xperia-x-performance/help/xperia-x-performance-f8132-t3422906 here
Hi All,
I got an issue bothering me since I bought Xperia X Perfomance (F8132) Mid June.
The auto rotate function failed after a while but everything goes fine after reboot.
When it fails, I use "Xperia Service Menu" -> "Service Tests" -> "Accelerometer",
then all X,Y,Z are zero and the ball just sticks and freezes at mid.
I bought from Taiwan and I can find 15 more people having the same symptom with me on 2 forums
( http://mobile01.com and http://gamer.com.tw ).
Hence I don't think it's only me and it's a common issue or common yield problem for Xperia X Perfomance.
I post here because I'd like to find more people with the same issue and raise the attention of SONY in order to find the root cause (i guess it's either over-heat causes this or accelerometer yield issue) and give a patch.
Now I'm using a APP "Rotation Control" to workaround this, but all photos cannot records correct orientation data and no auto-rotate is kinda inconvenient.
For a flag-ship and high-priced cellphone for SONY this year, it is very disappointing to me.
Version: 35.0.A.1.227 and 35.0.A.1.238 both occur
Another case here:
I'm sorry to hear that
Would it be possible for you to take a log from your phone when the accelerometer has stopped working and send it to me in a private message?
To do this:
Settings > About phone > Build number, tap 7 times on the build number
Go back to Settings and select Developer options and turn on "USB debugging". Then tap "Logger buffer sizes" and set this to "4 M".
- The next time you notice the accelerometer is not working:
Settings > Developer options, select "Take bug report". When the report is ready (may take a minute or so) you get a notification that you can tap and share to Google Drive. Please send me a link to this file in a private message.
Thanks again for the logs you sent me!
Based on what could be seen in the logs, the latest software update (35.0.A.1.275) that's currently rolling out should help. When checking your IMEI i see that this version has not rolled out for your operator/market yet though. I'm afraid it's not possible for me to see when a certain country/operator will receive the update so right now i can only recommend that wait for this update to reach your phone.
In case this should still happen after the update to the new version, please let me know.
Sorry to hear that it still doesn't work properly.
Would it be possible for you to take another log on the new firmware and send this to me in a private message?
