Sony Tablet S Update problem
profile.country.en_GB.title
gt19300
Visitor
Yesterday I updated to latest Android version 4.0.3 release 1. Now the onscreen keyboard is not available. When I try to type in a URL this opens google voice type and a screen saying 'waiting for results' with a never ending circular rotating icon.
13 REPLIES 13
Thalamus.
Champion
Hi gt19300,
Welcome to Questions & Answers..:smileyhappy:
Open settings..
Then under Personal tap on Language & Input..
Under Keyboards & input methods ensure Google voice typing is NOT selected & that Standard Keyboard IS selected..
Leginsmith
Visitor
There is loads of confusion and problems since the update to 4.03. Even people with other makles of tablet are having many problems.
My sony will not allow me ot use play, gmail, talk or any google app, it keeps saying GAPPS error or server error.
COME ON SONY GET IT SORTED
PeterEB78.9
Visitor
Hi, I've   had three lock ups since the last update, only way out is to rest. If you havn 't got a suitable pin around it seems that a very long press on the on/off button does a reset, but a fix would be better.
gt19300
Visitor
Thank you, but under keyboards and input there are 2 entries only. The first is Default (Automatic - Google voice typing) and under this the second is Google voice typing - (Automatic.) There isn't the option to deselect or any reference to Standard Keyboard. I've done a soft reset, didn't solve it.
Message was edited by: gt19300
Contacted Sony Support 16th Aug. and went thro' factory reset, didn't solve it. They are escalating it and will respond on Monday 20th.
Sony rang yesterday 20th. No resolution available, Will ring back Friday 25th. Have now lost confidence in Sony.
Thalamus.
Champion
Hi gt19300,
could you supply you Sony support case number please & I'll see if I can get someone check this out & contact you..:smileysad:
profile.country.fr_FR.title
massilia69
Visitor
welcome to sony world,
same as you all ,
stuck with the last release ,
none of google apps works,
and they have no solution at the moment!
hot regards from France
gt19300
Visitor
Case Number is 7071102. Thank You.
Thalamus.
Champion
Thanks, I have passed your case number & directed Sony support to your comments in this thread, I hope someone gets in contact with you soon..
gt19300
Visitor
Thank you. I'll let you know any outcome.
