Partilhe a sua experiência!
Caro Noddy-coroas,
Bem-vindo ao forum da Sony...
Penso que isto poderá ajudar...
How to use a Sony® camcorder as a webcam using USB Streaming. | ||
IMPORTANT:
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software. |
Cumprimentos
