I have had a new Bravia for all of five weeks. Its been working perfectly. I love it. Then tonight it just switched itsself off. I turned it on and it lasted thirty seconds before flicking itself off and then back on and then off.....
Its connected to a Sky Box but its not making any difference whether I switch it on with the remote or manually. It just turns itself off again.
Anyone experienced this?
Thank you.
Solved! Go to Solution.
