I did a factory reset of my TV today. Now Sony select will not load, which means I am missing BBC iPlayer and Amazon Prime.
I tried manually starting but it comes up with the above error. Was all working fine until reset, tried multiple factory reset and still same error.
What is causing the problem, I have the firmware that came out last week
Sony XE90
Solved! Go to Solution.
