Who Me Too'd this topic
DSC HX50 - sensitive control wheel
Hi,
I have a DSC HX50 - it's about 24 months old with very little use. It has developed a fault with the control wheel in that it has become hyper sensitive to the point that it scrolls through options without touching it. Coincidently my daughter has the same camera (on my recommendation!) and it has developed the exact same fault. My main question is whether anyone else has encountered this problem or even if it is a known fault Also, if there is a known easy fix.
Thanks
James
