Hi guys,
Started having an issue this week, when using tv guide or trying to scroll up or down or across on the home screen or guide, the remote will not work I.e.it will not tab across or up or down.. I need to reboot the tv then it works ok. After a you put the tv on standby, you then need to do a reboot again as it reverts back to not working. Anyone else had / have this issue.
