Who Me Too'd this topic
PhotOguz
Explorer
Sony α7 MK2 - Auto ISO Minimum Shutter Speed
I would like to note that the minimum shutter speed and auto iso issue is still the same like in the previous version. Most of the time it's not a problem, but if you work with manual lenses it's annoying not be able to work in Aperture Priority Mode as shutter speed is not fast enough. You need to adjust ISO manually then.
Better would be when the software would take a short shutter speed like 1/160 or 1/250 and increase the ISO automatically. If I would need lower ISO then I would adjust it manually instead of other way.
Shouldn't be a problem to solve this via firmware update. I'm wondering why this wasn't done since the A7/7r as this problem weas reported before. It should have been solved with the new A7II.
