Who Me Too'd this solution
sib_12
Explorer
You can find out which particular Bluetooth adapter you have
by looking in the Windows 'Device Manager'
( 'Device Manager' is found in the Windows 'Control Panel'. )
Open the Device Manager and look through the tree-view of devices.
Locate the 'bluetooth' device which will likely be inside a 'Bluetooth Radios' category.
Right-click on the Bluetooth adapter icon to bring up the pop-up menu and then choose 'properties'.
That'll open a Properties dialog window.
Click on the 'Details' tab and from the drop-down list and choose 'Hardware IDs'
If it is a PCI-bus connected device then you should see something like this :
    PCI\VEN_8086&DEV_0162
If it is a USB-bus connected device then you should see something like this :
    USB\VID_1234&PID_5678
The significant information here is :
VEN ID = 8086, DEV_ID = 0162 (for a PCI connected device)
VID=1234, PID=5678 (for a USB connected device)
You can then do an internet-search for  PCI vendor id database
or USB vendor id database (whichever is appropriate) and that'll take you to a web-site
where you can lookup who the manufacturer is and what particular model - e.g. chipset and model number -
of device that you have.
