Who Me Too'd this topic
Andrew649
New
HXD995 lost digital channels
I have seen this problem on the forum but suggested remedies have not worked.
This morning I found my HXD995 stuck on update. No response from controls and when switched off at socket reverted to update on reconnection. By switching off at socket and instantly pressing on at reconnection I managed to switch on recorder. However all digital channels failed to work. I tried rescanning which found the channels but still could not tune in. The digital guide was empty.
I checked the firmware which is 1.24. I then reset the recorder but made no difference. (I rechecked the firmware after reset, still shown as 1.24)
I tried update but again it stuck. Also I note when I change digital channels (none of which worked) the number of channels I can check is very few, refuses to try higher numbers.
I would appreciate any help on this. Thanks
Cheers
Andrew
