Personally I think the NC on the Wh-1000xm3 I recently purchased is poor, I am currently on train can here the noise of the train, people chatting and the announcements. Not what I would expect that for nearly £300
Hello @Jimlibob,
you probably have "Adaptive Noise Cancellation" switched on.
Deactivate it and drag the slider to the far left.
- Nic
Hello
Checked that and have pressed and held the NC button to optimise.
Hello @Jimlibob,
that is not what I meant - install the "headphones connect app" on your phone and check what settings are applied to your headphones.
If I recall correctly, the default settings have "Adaptive Noise Cancellation" enabled.
- Nic
Ah OK not using them at the moment but will double check fingers crossed I feel like a fool for starting this thread
App is downloaded by Headphones currently not on my person
Slider far left and adaptive sound control off. Noise cancelling nonexistent
