WH-1000XM3 and ALAC
fedbcc
New
WH-1000XM3 and ALAC
Hi all,
I am using PLEX to play ALAC files. I am aware these headphones support 5 different codecs via Bluetooth (SBC, AAC, aptX, aptX HD and LDAC). So I suspect somewhere in the chain ALAC must be converted to one of the codecs above. So my question is: how do I choose which of the 5 codecs is used over Bluetooth?
Thanks.
Kind regards,
Federico
2 REPLIES 2
EdwinaU
Moderator
Hi Federico,
Welcome to the Sony Community.
We will check this and let you know as soon as we have more information for you. Some of our members may also be able to help.
Best wishes,
Ed
The_Black_Rose
Specialist
Hi Federico,
As far as I am aware, both ALAC and AAC use the same compression method so I don't think that the playback codec can be changed, well, at least from the headphones itself from what I've seen in the Manual of the headphones. https://helpguide.sony.net/mdr/wh1000xm3/v1/en/contents/TP0001703175.html
Cheers,
The_Black_Rose
