syncronize music to Walkerman
SOLVED
profile.country.no_NO.title
mortenaasen69
Visitor
How can I syncronize music to Walkerman from my ITunes library
MAA
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.en_GB.title
Drumzman
New
Hi mortenaasen69,
It depends a bit on what Walkman you have, but if there's a 'Z' in the model number e.g. NWZ--- then you should be OK.  I'd recommend using a bit of Sony software called Content Transfer (link below) as you can drag your music directly from iTunes and drop into the Content Transfer window that will then do all the work for you!
I've been using this for a while now, and it works pretty well.
http://www.sony.co.uk/support/en/product/NWZ-X1060/downloads/Con_trans13
Hope that helps
2 REPLIES 2
Drumzman
New
Hi mortenaasen69,
Hope that helps
tetrapackage
Visitor
Thanks a lot for this information. So far, mine have a Z on it's model number. I guess I don't have to worry to much.
