Sony CDX-GT25 display
profile.country.en_GB.title
Pants1974
Visitor
I have moved my head unit (CDX-GT29) from one car to another, and the thing works but the display is fully displayed. ie it will not change anything on the display?
Any ideas guys
2 REPLIES 2
Drumzman
New
Hi Pants1974,
I think I'd try removing the front panel and cleaning the terminals with a cotton swab first of all.
If this doesn't work, many of these stereos have a reset button on the main unit underneath the front panel - if you have one then that could also be worth a try.
Hope this helps.
tetrapackage
Visitor
Cleaning would be a good idea. That is how I fixed mine in no time.
