Sony XAV-AX3005 compatibility with a 2011 Toyota corolla
danw200000
New
Hi
i gather that this unit will fit into my 2011 Corolla, however:
1. does the box contain an frame adapter ?
  • in other words, will i be able to connect this to my car without any additional parts?
2. what kind of cable adapter do i need to connect my steering wheel controls to the unit?
thanks!
2 REPLIES 2
EdwinaU
Moderator
Hi,
Welcome to the community.
We will check this and get back to you when we know more.
Best wishes,
Ed
The_Black_Rose
Specialist
Hi Danw200000,
I've just had a look into the supplied accessories and I can see that a Fitting Frame is supplied.
I believe that there's no certain recommendation for this one. Usually the manufacturers do not guarantee the functionality of external adaptors.
Cheers,
The_Black_Rose
