opening up software
profile.country.en_GB.title
stevewwwwwwwww
Visitor
opening up software
i'm trying to install the software for my nw-a300 on a new laptop, but when i try to open the programme, i get the message 'limited user accounts are not supported' and won't open
6 REPLIES 6
Thalamus.
Champion
Hi Stevewwwwwwwww,
Welcome to Questions and Answers..
Are you logged onto your laptop using a limited user account.?
If so have you tried logging on using an administrator account to install the software on your laptop.?
stevewwwwwwwww
Visitor
thanks for the reply. i am the only user of this computer so i've never considered it. what do i need to do as i'm not that computer literate?
Thalamus.
Champion
Hi,
try right-clicking on the walkman instalation/set-up .exe file and select Run as administrator
stevewwwwwwwww
Visitor
hi
when i try that i get a message referring to 'missing NTMSAPI.dll file'. i'm none the wiser!
Thalamus.
Champion
Hi  stevewwwwwwwww,
what is the name of the software you are trying to install.?
What operating system is installed on your new laptop.?
Convergence
Visitor
Hi
The ntmsapi.dll file is associated with the Removable Storage Public Interfaces ( RSPI) in the Windows XP system.
I suspect you are using Connect Player or Sonic Stage for the NW-A3000, i would recommend looking at the http://forums.sonyinsider.com/ forum as Sony no longer support either package for Windows Vista or 7, they have some good work arounds
