OMA files
profile.country.en_GB.title
cfranca
Visitor
OMA files
Hello.
Anyone knows how can I play OMA files?
Help!
3 REPLIES 3
profile.country.FR.title
ClarkLong
It depends if your oma files has DRM or not. And since Sony drop the atrac3 codec, even on their own devices!  The compatible hardwares are limited.
If yes=> only the computer that run the Sonicstage software that created that file can play it.
If not=>right now, only the PS3 can read those files
jomcgin59
Visitor
Have you tried winamp, it plays atrac files, with a littel bit of editing in options
1.  go to Preferences
2.  Select Plug-in....input
3.  Select  Nullsoft directshow decoder, and configure
4.  Add file extensions  to configuration   omg;oma
5   Select ok, and close
And now winamp should play omg/oma files
Message was edited by: jomcgin59
jumpsuit
The ever popular and free VLC Media PLayer from Videolan  states it plays OMA files although I haven't tried it.
VLC plays pretty much everything you can throw at it :slight_smile:
