nwz-b183 usb mp3 player songs skipping
jodolot
New
Hi there,
I have recently bought the NWZ-B183 USB MP3 player for use in the car but when I copy songs onto the player and plug into the car USB port, the songs kind of skip a couple of seconds. When I use it without plugging into the car USB, the songs play fine. I have tried different PC's and different copy software but same issues. I have even tried another USB MP3 player, the APTEC I think it's called and that plays fine.
Has anyone else encountered this problem before?
Best Regards
1 REPLY 1
Sean_Mc
Moderator
Hi there,
Welcome to the Sony Community.
The sound can skip depending on the environment where your Walkman is used or the settings of your Walkman.
Can you try to set all sound quality settings to off and let me know if this helps?
Best wishes,
Sean
