Cannot download music tracks from the pc to the NWZ-B172. I get red crosses against each track with error message regarding device certificate. Please advise of any solution.
Hi there, just had the same problem and was getting very frustrated, so went onto a similar forum as this and found an answer that worked for me and fingers and toes crossed! - it seems to be working fine - here's a copy of the info:
Open Windows Media Player
Click on Rip (on the tiny drop down arrow) to give you the options list
Click on Format and this will give you a list of file formats
Change the file format to MP3.
This means that the files you're downloading from a CD will automatically be changed to the MP3 format compatible with your MP3 player. You should then have no problem adding tracks/albums to your sync list and then transferring to your player.
You may however need to remove the CD you're using and rip it again into MP3 format.
Hope this helps
Kaz
