NW A45 when unmounting SD card?
Canadianguy54
Member
When you unmount these cards with all your music still on. is the music still good? Getting a bigger card. Can you slide that card back min at a latter date?
Thanks
4 REPLIES 4
Anonymous
Not applicable
Hi there,
Hopefully a community member can help.
Best wishes,
M
The_Black_Rose
Specialist
Hi Canadianguy54,
The music on the card shouldn't be affected if you remove the card. Just make sure that you don't expose the device to any physical damage to avoid  file corruption.
Cheers,
The_Black_Rose
Canadianguy54
Member
Hi...is the difference between a Sandisk 128 sd card A1 and a Sandisk 128 card? Just speed? One is a 100mb and one is 80 is that it. Will that effect at all the playing?
Thanks
Sonyvores
Contributor
it won't change much for a music player.
