Nm a45 walkman sound issue
jefferio
Explorer
Hi
For some reason when I play my walkman after not using it for a bit the track plays but no sound? Then after a minute or so it starts to output. The track is playing, I just have to wait?! This is with headphones plugged in by the way.
Any ideas??
7 REPLIES 7
Sean_Mc
Moderator
Hi there,
Welcome to the Sony Community.
Can you try to reset your Walkman player. If the issue is not solved, charge the player for about 30 minutes, then try to reset again.
Let me know how you get on?
Best wishes,
Sean
jefferio
Explorer
Hi Sean
Thank you for the response.
When you say reset. Do you mean power off. Then back on? Or do you mean a full factory restore/reset?
Thank you 🙂
jumpsuit
Hi @jefferio
Yes, try the factory reset :slight_smile:
Sean_Mc
Moderator
Hi again,
Please see more details on resetting your Walkman here.
Best wishes,
Sean
jefferio
Explorer
Thank you for your responses!
So far, so good. But the original problem was very random. I'll give it a day or 2 before I update you all.
Thank you guys 🙂
jumpsuit
You're welcome :slight_smile:
Fingers crossed :wink:
jefferio
Explorer
Hi guys
Unfortunately it hasn't worked. Just now I picked it up, switched hold button to unlock it, plugged headphones in and pressed play. Begins to play, you can see on the display, but no sound. 30 seconds or so later the sound will suddenly output 😕
