MEX-BT4000U
profile.country.ro_RO.title
CosmionB
Visitor
MEX-BT4000U
Hello. I just bought a sony MEX-BT4000U and installed it on my car, but I am having problems memorising the settings. Eg.: I memorised radio stations on positions (1 - 2...), set the clock, adjust the equaliser, turn the DEMO mode OFF etc, but after i remove the key from the  contact it is all lost. I read the manual, I tried different things, but I have no idea what I am doing wrong. Could someone help me, please?
2 REPLIES 2
profile.country.en_GB.title
Convergence
Visitor
Hi CosmionB you need to check your wiring, it would appear you don’t have a permanent live connection, this is what is used to maintain memory settings.
CosmionB
Visitor
Thank you very much; I will check the rest of the wires and make the necesary adjustments.
