Greek language support
SOLVED
profile.country.en_GR.title
disevas
Visitor
I own a NWZ-S765 walkman player. I wonder why it would not support Greek language settings. Any time I add something through my computer it appears Chinese. Since this product is officially represented and marketed in Greece, can anyone tell me if there is some sort of upgrade to include Greek language settings?
Tags (2)
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
Hi disevas and welcome.
This is a user forum - so you will not get an answer here.  Have you tried talking to Sony Support?
As you say, Greek is not supported at this time: -
http://pdf.crse.com/manuals/4288581121/ENG/contents/11/09/01/01.html
:thinking:
2 REPLIES 2
disevas
Visitor
Anyone?
Blencogo
:thinking:
