connection problems with nwz-b163
profile.country.en_GB.title
jonno007
Visitor
hi all
i have a new nw-b163 mp3 player, evertime i try to connect to napster i get an error message appear,
your player digital rights are corrupted ,
i have tried everthing , formatting the device , after hours with the napster helpline ,it seems its the device that needs a firmware update,
i cannot find anywhere to update it
i also have an older sony mp3 and that works fine with napster so i know its not an account problem
many thanks
3 REPLIES 3
frazfraz
Visitor
Hi,
I get something similar and cannot get my new NWZ B163 to sync with Napster - A while ago I bought the NWZ B135 and it synced with Napster in seconds but this new 163 version just won't work.
What is the problem - does it need a driver? - I have reformatted the devcie yet it still will not work.
Someone mentioned a firmware update for the NWZ B163 - Is there one available to download and install onto the device via the USB port??? - Or does the unit need to be sent back to Sony?
Answers please and quickly!!!!!!! -
jonno007
Visitor
pm sent
apparently this device is not compatable with napster ! as it dosent support the drm needed
if anyone knows different , then please lets us know,
frazfraz
Visitor
If you look on Google and search for Napter TO GO compatible devices you will see lower down the list that the Sony B series walkmans are TO GO compatible.
I have been using B 135 no problems at all with Napster Sync
B 163 has not worked - Something is clearly wrong and it looks like Sony may have made this device  incompatible with Napster sync.  The reason I bought the Sony B series 163 was because of this compatibility.
It should work and that is all that there is to it.
Message was edited by: frazfraz
