CDX-GT540UI USB problem
SOLVED
profile.country.en_GB.title
AidanHarris71
Visitor
Hi
The unit recognises the USB stick, scans through and recognises how many albums and tracks are on it, but doesn't play.
Any ideas?
Cheers
Aidan
1 ACCEPTED SOLUTION
Accepted Solutions
AidanHarris71
Visitor
I've solved it.  I was using .wma files, which the manual says the unit recognises, but it actually doesn't.  I'm now using .m4a which are working fine.
Cheers!
2 REPLIES 2
austingrd
Visitor
What file types are these? Can you try a sample or test using the sstandard mpe file? https://imagicon.info/cat/12-13/vmware_happy.gif
AidanHarris71
Visitor
Cheers!
