Hi
The unit recognises the USB stick, scans through and recognises how many albums and tracks are on it, but doesn't play.
Any ideas?
Cheers
Aidan
Solved! Go to Solution.
I've solved it. I was using .wma files, which the manual says the unit recognises, but it actually doesn't. I'm now using .m4a which are working fine.
Cheers!
What file types are these? Can you try a sample or test using the sstandard mpe file?
