I've just purchased the above and some albums have the cover image on the Walkman and others don't. I have found the cover image on the internet and can add it to albums in Windows Media Player but that doesn't add it to the Walkman. I've tried Sync'ing but that doesn't do it either.
Any ideas??
Solved! Go to Solution.
Hi keitht if you have updated the files TAG data in Windows MP you will need to replace the files on the Walkman, I dont think WMP can do this on its own, you will need to delete the ones on the Walkman and then add the updated version
