My Wireless Switch Setting Utility is gone, now I can't disable My bluetooth anymore!!!
In device manager I disable the bluetooth device but bluetooth keeps working. In Vaio Controll Center the option to get to the wireless switch is GONE. I also removed and reinstalled the wireless switch, but nothing helps. It's installed but it does not run or work.:smileycry:
Hi Carelino,
I am not sure about this but it may be worth re-installing the Bluetooth driver and utility.
1) Ensure that the hardware "WIRELESS" button is ON
2) Open the Bluetooth driver folder and double-click "BtSWinst.msi" file to start the installation.
