wireless driver
callumw10
Visitor
wireless driver
i am trying to install the wireless driver from sony's website onto my laptop. i have downloaded it and opened the file there is two files which i can right click and click install on.when i have done this it asks me if i want to open the file i click open then i get a message saying:
the inf file you selected does not support this method of installation.
i am downloaing the file from this link:
http://www.vaio-link.com/downloads/info/info.asp?site=voe_en_GB_cons&url=Vaio/Original/Wireless%20LA...
i have a vgn-nr31j/s
i do not know what to.
if you want you can email direct at [email protected]
thanks
callum
2 REPLIES 2
Blencogo
Hi Callum.
Welcome to Club Vaio.
You will need to install the driver from Device Manager.
1. Find the wireless device in Network Adapters in Device Manager and double-click on it.
2. Go to Driver tab and select Update Driver.
3. Select Browse my computer for driver software.
4. Select Let me pick from a list of device drivers on my computer.
5. Select Have Disk....
6. Select Browse....
7. Browse to your back-up driver .inf file (\\netathr.INF) wherever you have it stored.
8. Next ..........
9. If you get a warning screen, select "Install Anyway".
10. Close & Re-Boot
Good Luck
:wink:
callumw10
Visitor
hi thanks for the reply
i have tried the suggestion and it did not work i had to roll back the driver to get it to work again. the software which was on the laptop twhen i brought it did not install. something did install but it did not work.
do you have any other suggestions?
thanks
callum
