VPCEB1E0E/WI - One quick question
profile.country.en_GB.title
nomeames
Visitor
VPCEB1E0E/WI - The spec says Wireless LAN Type supported - 802.11 b/g/n. Does anyone know if it supports 802.11n @ 5GHz frequency or is it 2.4GHz only? :thinking:
2 REPLIES 2
Thalamus.
Champion
Hi nomeames
it would appear only 2.4 ghz can be used, see image
nomeames
Visitor
Thanks Thalamus. I was thinking of upgrading my current netgear G router to a dual band router (to keep the N and G devices apart). It seems running N and G devices on 2.4GHz brings the network down to G speeds. Any idea if I can (easily) upgrade to 5GHz band?
