VGN-FZ31L Keyboard Driver Problem
profile.country.de_DE.title
fawende
Visitor
hello,
im from germany and i got an older vgn-fz31l with vista  64bit.
1. Question: i reinstalled the opperating system and i dont have the original  drivers for my sony. after the install from vista 64 bit the keyboard  first works but other stuff dosnt, couse of missing drivers. now the  problem is that my keyboard didn't work anymore till i updatet the  system to service pack 2. i got several drivers for the laptop from  here:
http://support.vaio.sony.eu/computing/v ... =VGN-FZ31L
but  i cant make my keyboard working and its even not illuminated, touchpad  is working fine. and wlan switch works but its also not illuminated :slight_frown: ... i also looked 64bit drivers up in here:
http://vcl.vaio.sony.co.jp/download/uno ... 4/001.html
but cant find what im searching for becouse i dont really now what i need to install 😕
2. Question: I lost my backup usb stick where the first operating system which came installed on the vaio & and where every driver was installed on (on the operating system) vista 64bit, is there a way to buy or to get such cd or usb stick or to reset the vaio to standart operating system ??
hopefully you can handle my problems. :slight_smile: yours Sonyshogun.
2 REPLIES 2
profile.country.fr_BE.title
benste
Contributor
There is a german part in the forum which you used to post in, but your question is written in english - that's why I'm moving your topic to the UK section.
1. VGN-FZ keyboard doesn't have illumination !
2. you can buy new recovery disks from Vaio Link - just ring them
fawende
Visitor
sorry i meant numlock etc with illumination. also the wlan switch on & off isnt illuminated.
wlan bluetooth and power is illuminated.
if i needent to buy the recovery disk, i would like to know a solution to make my keyboard working again :slight_smile:
