I've accidently scratched my vaio top cover,it doesn't look nice,I'd like to replace it, but I don't know where to get it.Any help?
Hi gabibacsi and welcome.
You could contact Sony Vaio-Link Support for a quotation.
http://support.vaio.sony.co.uk/contacts/contacts.asp?site=voe_en_GB_cons&tp=vaio&cc=en_IE&cm=phone
Alternatively, you could order one from the USA - NextTronics will ship worldwide.
http://www.nexttronics.com/reference/sony/fe7/ext-FE51B-H.htm
Thanks for the quick answear.I'll check out both of them and I hope I'll find some solution for my problem.thanks again.
Hi gabibacsi,
have you thought of a Lapjacks as a cheaper alternative solution.?
Lapjacks are made from a high quality adhesive vinyl which you apply to the laptop lid to personalise and protect your notebook computer, click HERE to read more..
