Has anyone managed to wall mount one of the 24in Vaio VPCL11 series using the built-in backplate? Sony is no help at all although it makes the desktop and highlights the wall mounting feature in the manual. Thank you if you know the answer
Solved! Go to Solution.
Hi tonynunn,
The manual says:
This means any VESA Wall mount will do the job.
Hope this helps.
Kindest regards,
Nico
Hi tonynunn,
The manual says:
Hope this helps.
Kindest regards,
Nico
Thanks for that Nico. Your were quick off the mark and pointed me towards some good Vogels tilting wall mounts. Sony UK worried me by telling my vendor that wall mounting might do damage to their big Vaio so why put in a mounting plate I thought. In seeking help I've also hoped to hear from other users who'd gone down that route . I'd like to allay my fears. Thank you. Many best wishes, Tony
