SR11MR Power Consumption Issue
Anero
Visitor
Hello everybody!
Just got my SR11MR laptop. Everything works fine except for the power consuption level when on the battery which keeps dissapointing me.
Vista tells that battery will last 2.5 hours and that's on all power managment profiles.
I check with Vista in-built performance metrics, used Right Mark CPU utility which shows power consuption level and it always - 17-20W whatever i do.
If i have max brightness, everything switched on: -17-20W and 2.5 hours until battery is almost 0. And the same stuff if i have everything switched off, brightness on minimum, etc.
It seems, there might be some kind of a soft issue... Any ideas? Probably someone has experienced the same problem?
0 REPLIES 0
