No 3G Connection Utility?
meansizzler
Visitor
So they decide to brag about their 3G everywair connection, yet they don't even give you the connection software to use your own sim card with it, they are bascially forcing you to use the T-Mobile sim they supply with it and that's the only connection utility they supply, there is a globetrotter 3G datacard built into it but where is my globetrotter connection utility?
3 REPLIES 3
profile.country.fr_BE.title
benste
Contributor
Normally you'll get the specific Utility from your ISP.
The only reason for the preinstalled software are the 30 days for free
If you want to use another ISP like vodafone,
use their link:
http://online.vodafone.co.uk/dispatch/Portal/appmanager/vodafone/wrp?_nfpb=true&_pageLabel=template1...
or simply google for others.
Edit: also see Blencogo's reply in one of your other threads HERE
ccvseelen
Visitor
...or use this universal freeware one which works brilliantly for me.
http://www.mwconn.com/english.html
benste
Contributor
or simply use a preinstalled utility in a linux system :tongue:
http://www.gnome.org/projects/NetworkManager/
