sony vaio vfg-fw486j/h video card replacement
SOLVED
profile.country.no_NO.title
groffse
Visitor
I was wondering if it was possible to upgrade the video card?? My current video card is
ATI Mobility Radeon HD 4650 AND I want something better. I've looked around and it seems more than possible to do.
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi groffse,
Do you mean VGN-FW486J/H? If so the answer is no as the graphics chip is soldered to the motherboard – it is not a card.
Rich
Go n-éirí an bóthar leat
1 REPLY 1
rich912
Contributor
Hi groffse,
Rich
