Hiya,
How do I make my DVD Player on my PC Multi-Region?
I use Power DVD.
Rick.
You could try:
- DVDGenie
- DVD Region Free
See which one works for you.
are they proggys and where do I get them from?
You will have to use DVD region free from www.dvdidle.com
Because your drive has RPC2 firmware DVD genie will not work.
Regards, Rob
Regards, Rob
Have you tried the Pro version - the one that caches the data from your drive?
If you have, does it reduce drive access as much as the site claims?
Regards, Rob
Regards, Rob
Caching just means that it reads a big chunk of data from the DVD to memory and then uses the data in memory to play the DVD.
It should save battery power (on a notebook) and reduce the time your dvd drive has to run to play a DVD thereby reducing wear and tear on the drive.
Probably not a huge problem for your desktop machine however
Regards, Rob
Regards, Rob
Thank you for your reply - The sooner DVD region coding goes the way of the Dodo the better.
Regards, Rob
