Looking for help with skype on my PCG-FR415M
every time I make or receive a call, the system hangs, needs a reboot.
I have checked the settings and they are ok. No conflicts show on the system and I have the latest version of all my drivers and skype. Any help appreciated
musket129,
Welcome to ClubVaio :smileygrin:
Could you check if the videocamera drivers are correctly installed, because this is the main cause of conflict with Skype.
Take a look in the device manager.
It seems there are a few people experiencing similar problems.
I assume you have uninstalled / reinstalled skype or even gone to an older version?
I haven't found any definate fixes as the skype support apparently just tell people to reinstall etc.
Edit: People running p2p software have also had problems with system freezes.
All drivers are correctly installed, Skype hangs the system wether i'm using the video or just a voice call. Camera and voice work in yahoo and MSN, only skype has the problem, and I have installed and re-installed this several times.
