Not possible to apply Firmware update to Version M010 |
I've tried to update the firmware for some hours using Izone HUB 1.0.6.1 software on HDMI and DP display ports, different USB cables and ports, using 2 laptop PC's with fully updated Windows 11 and up to date drivers, different USB hubs, several plug/unplug, turn on/off tasks, Windows restarts and PC shut downs. Every time I get this: |
Hey Jack, try unplugging everything from the mains and remove any external devices, follow the steps on the updating link and start fresh: https://www.sony.co.uk/electronics/support/monitors-inzone-m9-series/sdm-u27m90/software/00281126
And here: https://helpguide.sony.net/tv/u27m90/v1/en/contents/TP1000670514.html
If nothing helped, send it for inspection:
