Does anyone know of a screen cleaner that doean't leave streaks (especially with the x-black screen). I have tried a couple of products all seem average:
Fellowes - Scrren Cleaner
Electrolube - ASC (anti-static cleaner)
Ordinary window cleaner (Mr Muscle)
What do Sony use?
After buying and trying several cleaners and applicators I have come to the conclusion that Allsop ClearView Plus (with applicator) is the best product to clean X-Black LCD's.
It does take a while to get a technique (like most things I suppose)
Tips!
- Clean screen when PC is turned off.
- Never use toilet roll, lint free only.
Thanks for the info
BELKIN LCD Cleaning System (Clean your LCD flat-screen and laptop monitor screens).
Can I use it to clean the X-Black LCD, I mean is it good?
Belkin usually make very good products, so I'd say yes.
You dont need to use any chemicals, just use a good quality glasses cloth, this will get all the fingerprints and other gunk off your screen
Just a quick note on the under-arm squirty stuff, its
DEODORANT
