problems with bios update need help!! :(
andreas1983
Visitor
:cry: hello together. ok i know my english is not good, but i really need some help.
im owner of a sony pcg fx 503 and i like to update my bios from version r0227u0 to r0247u0.
but i cant extract the file "r0247u0.exe" everytime he says "leider haben sie keine erlaubnis das software-paket zu öffnen" in english (i hope so :P) "sorry youre not allowed to open this software package"
i really need to update it so please gimme some tips 😞
greetings andi
8 REPLIES 8
rich912
Contributor
How are you trying to extract this file?
Are you using Bios Installer Tool WinPhlash (also available for download).
This process is carried out in DOS and if you are unsure of the procedure I strongly recommend that you read up on it first as a failed Bios upgrade can ruin your computer!!
Go n-éirí an bóthar leat
andreas1983
Visitor
hi
i loaded winphlash intalled it an so on
my problem is, that i cant start the bios file
in the manuel (before the download starts) they write
1. Download the file R0247U0.exe, and save it to a download directory (ex. C:\Download\). <--- i made this
2. Go the download directory, and double-click R0247U0.exe. WinZip Self-Extractor program starts. <---- here the failure appears
3. Click Unzip. The file will be extracted to a new directory C:\R0245U0.
4. Click Close to exit WinZip Self-Extractor program.
i know how to flash a bios but i cant extract it 😞
profile.country.de_DE.title
seb21__
Visitor
Wenns um BIOS geht schau mal hier rein.
http://www.bios-info.de/
Sorry I can't help you here.
rich912
Contributor
Have you changed your operating system from the original configuration?
rich912
Contributor
Also, rather than double clicking, have you tried right clicking and choosing the option 'extract to'?
profile.country.en_GB.title
kee-lo_
Member
Sorry if this has been suggested before but redownloading the file might help.
andreas1983
Visitor
hmm cant extract it by clicking ....
and yes i changed the pc configuration the hdd drive was broken.....
what can i do ? i need usb 2.0 pc card and my old bios is buggy ..... :((
and the new one supports usb 2.0 pc cards and fixes some issues :((
rich912
Contributor
But did you restore with the recovery disks or carry out a fresh install with a different disk? If so, this is probably the cause of the problem.
